 Photo is a 1937 L with colors that are pretty authentic, so far as I can determine. Standard color on the L was LC Gray, with Case Red wheels. Fan, magneto, radiator screen are black. Some photos show the front hub caps and rear wheel nuts black, also. There were some variations; apparently some tractors for municipal use were maroon. Decal lettering ("CASE") for later models is silver; on the earliest models, it was sand-colored. I've only seen one, and I don't know if anyone makes those early-type decals. On the later models, raised lettering is silver, and striping is red and white. I need to measure mine and refresh myself as to the correct striping layout measurements, and when I do, I'll post the info. The tractor is stored about 30 miles from where I live. Earliest L's had an oil cup for the rocker arms, that stuck up through a hole in the center of the hood. They also had a flat fan belt. Earliest models did not have embossed lettering on the sides of the hood; later ones did. Reproductions of fenders and both type hoods are readily available.
