2094
Coloken
05-26-2004 05:26:44
The search thing seems to be not working. What can you tell me about the 2094? Was it considered a good tractor or a lemon? What did it have for a transmission? Any outstamding problems?
Grumpy
05-26-2004 05:35:22
 Re: 2094 in reply to Coloken, 05-26-2004 05:26:44
2094 is same as 2090 but has electric controled powershift. It has 504 engine without turbo rated at 110 horsepower on the PTO. Very good tractor. Stan
Coloken
05-26-2004 08:46:52
 Re: Re: 2094 in reply to Grumpy, 05-26-2004 05:35:22
Is that powershift dependable? Friend looking at this tractor once had a bad exprience with transmission on , I think, a 13xx something. All in all, it was a real looser.
John Saeli
05-26-2004 10:15:56
 Re: Re: Re: 2094 in reply to Coloken, 05-26-2004 08:46:52
Hey Coloken: No better tractor built. My 2094 has close to 7,000 hrs. & the Power Shift has never been touched. Smooth as silk. I have 3 CASE tractors with the RPS34 Power Shift and they are all very dependable. As with any CASE engine, keep the ether can away.
ketch
05-26-2004 10:13:39
Currently have 2094,second owner,tractor has over 14000 hours on it(not a misprint),engine never touched,had to do powershift once.would not be afraid of buying another.Thanks
ketch
05-27-2004 06:52:44
 Re: Re: Re: Re: 2094 in reply to ketch, 05-26-2004 10:13:39
Good morning,the engine oil on my 2094 is faithfully changed every 100 hours and use the series 3 straight 30weight oil from case ih;trans oil,changed every 1000 hours/and yes,as a precautionary measure I will be changing rod and main brgs.Thanks
Coloken
05-27-2004 07:48:01
 Re: Re: Re: Re: Re: 2094 in reply to ketch, 05-27-2004 06:52:44
Hey you might have a record there. Best I ever saw was a Case 500 with 9000 hours and running like new. Best I ever ran was a CK 930. Blamed its long life on the fact that it had a second oil bath after the dry air cleaner. Had 7000 on my 1200 when I traded it off. Only thing with it was antifreez seep into crankcase during winter. Used coop 15/40 diesel in every thing I had. I'm wondering if that 2094 engine is the same basic 930/1030/1200 block that was so good?
DKase
05-27-2004 06:01:10
If your tractor has 14,000 hours on it and it has never been touched you better be thinking about a set of bearings. My 970 had 9,000 hours when I installed new bearings. When I started it up I was surprised to notice that it had been knocking. I had a wore out 830 several years ago that was not worth replacing the bearings. At about 15,000 hours the tabs wore off a rod bearing and it spun. Then it was not worth anything.
John Saeli
05-26-2004 19:16:31
Hey Ketch: 14,000 hours is a lot of hours for any engine. What is your secret? I go 100 hours between oil changes. I don't use Pennzoil or Quaker State. Absolutely no ether.
