1937 Case L Clutch Adjustment
cheg
05-29-2004 20:51:09
I was wondering if this a clutch adjustment problem? I have to push the clutch lever (hard) forward to put the tractor gear. I also have to push hard to keep the tractor from moving once the tractor is in gear. This can be tricky when trying to back the tractor in the shed. How do I adjust this out of it? The tractor always wants to move even with the clutch disengaged.
Robert Pence
05-30-2004 17:32:29
 Re: 1937 Case L Clutch Adjustment in reply to cheg, 05-29-2004 20:51:09
My 1937 L had sat for about thirty years without running, with the clutch disengaged, and I had the same problem the first time I started it. Because we had overhauled the engine and had the mag rebuilt, we thought it was safest to pull-start it the first time with my brother's LA. It took hold rather quickly, and when it did, I couldn't disengage the clutch. I ran into the back of the LA and shoved it into a tree before I got it to stop. Fortunately, no one was hurt and nothing was damaged.
I remedied the problem by loosening the clutch adjustment a little, and after we ran it a while it started to slip, so I tightened it back up. I think maybe the disk had swelled with moisture and disuse, and after a while it got back to normal. It's been OK since. Properly adjusted, it should only take a moderate amount of force to engage it. Operation should be very smooth.
The clutch runs in oil from the engine, and if the tractor hasn't been used regularly, it's a good idea to take out the drain plug below the clutch and try to flush out any accumulated sludge and goop from the clutch housing. Each time you change the engine oil, you should drain the clutch as well as the oil pan. It takes 17 quarts for an oil change!
cheg
05-31-2004 16:04:29
 Re: Re: 1937 Case L Clutch Adjustment in reply to Robert Pence, 05-30-2004 17:32:29
I hope that is my problem. The tractor has been sitting in a barn for years and years. Who knows when the oil was changed or tractor serviced. It probably needs to get out and be worked.
Robert Pence
05-31-2004 18:14:45
 Re: Re: Re: 1937 Case L Clutch Adjustment in reply to cheg, 05-31-2004 16:04:29
Cheg, if the tractor has been inactive for years, it could have a deep layer of congealed sludge in the bottom of the oil pan that could interfere with the supply to the oil pump. I'd drain the oil, take off the crankcase inspection plates, and scrub out the oil pan with solvent (and a putty knife, if necessary) and pull the oil screen (3 bolts on triangular pattern) and wash it in solvent, to make sure the tractor is getting plenty of clean oil to the pump. The L is a wonderful, tough machine, and you'll get a lot of pleasure from it.
Allan C
05-29-2004 20:58:11
The clutch adjustment will affect how hard it is to engage the clutch and how hard it holds. If your lever is hard to pull "over Center" you could try backing the adjustment off a couple of holes and see if it helps, but I suspect you have a clutch disc problem. Like a piece of facing that has come loose in the clutch.
Allan C
05-29-2004 21:02:19
 Re: Re: 1937 Case L Clutch Adjustment in reply to Allan C, 05-29-2004 20:58:11
I forgot! To adjust the clutch remove the rectangular cover from the side. There's a spring loaded lock pin on the engagement hub assembly that you have to pull out, and the hub can be rotated. It is on a thread, so counter clockwise from the clutch end will loosten the adjustment. It could also be the pilot bearing. either way, if the adjustment doesn't do it, you have to split it.
