ATT Don L. DC Main Barrings
CJ
05-31-2004 18:13:58
Would like to know if anyone has any and how much. Need 10 thousand under sized.
Don L.
06-01-2004 06:48:22
 Re: ATT Don L. DC Main Barrings in reply to CJ, 05-31-2004 18:13:58
Mains will be rebabbited to semi finished. Will have to line bore to size. Or take the shims out and hope for the best. New rebilt semi bearings sets are $175.00 on your cores.
Don L.
DCTOM
05-31-2004 18:17:48
CJ NOT NO SUCH THING JUST TAKE SHIMS OUT DC
CJ
05-31-2004 18:21:42
 Re: Re: ATT Don L. DC Main Barrings in reply to DCTOM, 05-31-2004 18:17:48
So does that mean that I can grind the crank and just take shims out because that does not sound right
Dave_D
06-01-2004 12:40:43
 Re: Re: Re: ATT Don L. DC Main Barrings in reply to CJ, 05-31-2004 18:21:42
To help clarify.
If the shims are removed or swapped for a smaller shims (check with micrometer) on the mains, this would reduce the size for the 10 thousand you are looking for. So basically the circle gets smaller to compensate for the warn crank.
Now the worry is, if too much is remove, say 20 thousands, the bearing may become egg shaped and thus the crank only rides on the top and bottom of the barring and the oil escapes on the sides.
But this only a low rpm tractor and this should not be a problem. (my 2 cents)
- Dave
Chico Tx
DCTOM
05-31-2004 18:27:57
SAID YOU WANTED .10 UNDER HOW MUCH YOU GOING TO GRIND CRANK?
