1950's Case VAC restoration
Edith Johnston
06-04-2004 12:31:10
I'm currently attempting to restore a 1950's Case VAC, and I'm having difficulty locating the serial number, model number and exact year of the tractor. If anyone has an idea where I might be able to locate this, or suggestions on parts or the restoration process please respond. Any information would be much appreciated.
John H-WI
06-04-2004 14:27:26
 Re: 1950's Case VAC restoration in reply to Edith Johnston, 06-04-2004 12:31:10
Hopefully the serial number plate is still on the dash. If it is post the number and someone will be able to tell you. The last years they were built they used a higher series of numbers. If the serial number plate is gone it is hard to pin down the exact year. The "V" guys can get you pretty close by checking for specific items on the tractor. For instance the eagle hitch came on the late 40's. If you could post a picture it would help very much.
As far as parts there are numerous guys are the country. Let us know what part of the country you are from and someone can help you. Also start making a list of the parts you need.
