1954 case w/eagle hitch gravity down power up?????
Dave
06-07-2004 16:50:49
Hello,
Can anyone help, my eagle hitch has hydraulic lift and gravity down, is this the correct application? I know the VAC eagle hitch is gravity down, how about the SC??
Thanks
Dave
DKase
06-08-2004 04:43:02
 Re: 1954 case w/eagle hitch gravity down power up? in reply to Dave, 06-07-2004 16:50:49
If you look at the hydraulic cylinder that opperates the Eagle Hitch you will notice that it is a 2 way cylinder, but the down pressure hose is plumbed into the hydraulic tank as a return line only. So the answer is no down pressure!
HOOSIER
06-11-2004 20:25:02
 Re: Re: 1954 case w/eagle hitch gravity down power in reply to DKase, 06-08-2004 04:43:02
We needed to get down pressure on our SC to operate a posthole digger. Took the line from valve to hyd resovour and hooked to top side of hyd cylinder. Good Luck
