L case how do you start thing
leland
06-14-2004 18:54:20
have an L case father inlaw passed and took secret with him HELP
RobertPence
06-15-2004 13:13:12
 Re: L case how do you start thing in reply to leland, 06-14-2004 18:54:20
Lots of good advice here. I agree that if you've never run this tractor before, it's safest to pull or belt it. Belting is the preferred method, because you can tinker with the choke, timing, etc., while it's cranking, if it doesn't start right away. Before you try anything, make sure the gas is fresh. Drain the tank, and open the drain valve on the bottom of the carburetor to make sure it's clean of old gas. Oil should be up to the top plug in the side of the oil pan, and it wouldn't hurt to remove the valve cover, tap all the valves/rocker arms to make sure none are stuck, and squirt the valve stems and rocker arms and shaft with oil.
Here's something to watch out for when pulling it. It happened to me, and someone else on these boards reported the same problem. When the tractor hasn't been used in a long time, the clutch may not want to disengage. Make sure you use a long chain or tow strap, so that if it starts and you can't stop it, you won't run into the tow tractor. That's why I think belting is safest.
leland cole
06-15-2004 18:03:26
 Re: Re: L case how do you start thing in reply to RobertPence, 06-15-2004 13:13:12
Thank's guys for all the great advise i'llpost a note if i ever get it running or if she sells first again THANKS A LOT
Brian in Ohio
06-14-2004 20:49:41
Turn on the gas, open the throttle lever about 1/4, give it three quarter turn cranks with the choke closed, then release the choke, and give it one more quarter turn, and it should run.
Be sure that when you crank the tractor, that you PULL UP on the crank and do not push down. And DO NOT wrap your thumb around the crank handle. Both of these procedures are to prevent injury in case the tractor decided to kick.
Do you know much about the old girl? What year? How long has it been since it has ran?
Drop me an email if you need any more information.
leland cole
06-14-2004 21:22:18
 Re: Re: L case how do you start thing in reply to Brian in Ohio, 06-14-2004 20:49:41
to brain in ohio i belive that it is a 36 or 37 hasnot been started in about 15 to 20 yrs just wanted to try to get it running if possiable be fore she gets sold
Dr Cy Kosis
06-14-2004 19:46:06
Veeeery carefully. That big horse can kick hard. Mines never bit me yet.
FIRST, make sure its out of gear. Turn on the fuel, retard the mag, set the throttle just above idle, pull the choke rod and roll it through once or twice, then crank 'er up. I cheat. I stand on the opposite side of the crank handle and push it downward with my right foot. If you pull the handle by hand, be sure you fold your thumb back rather than gripping around the crank. After it starts up the advance the mag.
My '29 still has the old Kingston brass carb, and it floods easily. Each machine takes some time for you to learn what it likes best for easy reliable starts. I can usually get mine on the first crank when cold, even after months in the barn. It's actually more obstinate whne the engines warm than cold.
If you are not sure its in running order as it is I'd reccomend pulling it to start the first time.
Al
06-15-2004 08:03:27
 Re: Re: L case how do you start thing in reply to Dr Cy Kosis, 06-14-2004 19:46:06
Pushing on the crank with your foot is extremely dangerous... If the old L decides to kick back your foot and all your weight are not going to stop it... you will likely end up with a broken leg.
A Case "L" should be started by retarding the spark about half way, throttle about half way open, then standing to the right of the crank, pull up on the crank with your left hand the first time with the choke on, then the second time with the choke off. It should start in 2 or 3 pulls. (Be careful as everyone has said to not wrap your thumb around the crank and make sure it is not in gear. Never push down on the crank when cranking any tractor, even the smallest tractors can kick back and break your arm).
Dr Cy Kosis
06-16-2004 07:16:28
 Re: Re: Re: L case how do you start thing in reply to Al, 06-15-2004 08:03:27
Broken arm, broken leg....I guess one has to make a choice. Either ones going to be inconvenient... and painful. I was taught by some old heads to do it by foot and have been doing it long enough any other way would be strange to me.
ted
06-15-2004 01:49:26
If I were you, valued my arms and wanted to avoid hospital costs, and had access to another tractor with a belt pulley and a belt, I'd belt her up and start her that way, or just give it a pull with another tractor. If you belt it, check to see that the rotation is correct, you may have to twist the belt.
