1949 vac
good old boy
06-15-2004 22:07:05
hey guy need a hyd pump for this vac it's the cam drive type not the one on the eng . the one down buy your left foot when you sditting on the tractor need it A.S.A.P ! THANK'S
Augie
06-16-2004 09:20:56
 Re: 1949 vac in reply to good old boy , 06-15-2004 22:07:05
I've got a couple that I'd sell cheap.
good old boy
06-16-2004 22:28:06
 Re: Re: 1949 vac in reply to Augie, 06-16-2004 09:20:56
Hey great i would like to find out what you have and how good of shape there in and how much you want for them , and are they as is or what !
Ryan
06-16-2004 12:05:32
Augie, you don't happen to have one that mounts on the engine too do you?
GeoMo
06-17-2004 12:33:53
 Re: Re: Re: 1949 vac in reply to Ryan, 06-16-2004 12:05:32
I have a combine pump on my VAC. I went back and found the following post.
Posted by John Saeli on May 11, 2003 at 10:23:04 from (66.66.189.222):
In Reply to: vac parts posted by bob missouri on May 10, 2003 at 14:50:35:
Bob; If it helps any, that hyd. pump should be the same that CASE used on the "600" combine, maybe some others also. Might be some left in the boneyards around. Hope this helps, John
Augie
06-17-2004 09:31:44
Nope. Just the kind that mount to the side of the torque tube.
