Re: Re: Re: 1952 VAC Starting Problem
C. Amick
06-21-2004 09:48:09
Could you be loosing too much amperage through the key switch? Might take a heavy wire and jump it across and see if that helps. Otherwise, I figure your starter needs cleaned. Sometimes the armature gets dirty and the brushes don't make good contact.
