1946 Case VAC question
Mike@NY
06-21-2004 18:05:21
Hello all, I just purchased a Case VAC, my first Case. I have three other farmalls. I will have an I&T Manual on the way shortly, but I hope you can answer this quick question. My Case has a keyed on off switch (which I don't have the keys for) with three terminals on it. I know it is not for a keyed ignition. Can I replace this switch (If i can't find the keys or a replacment switch) with a simple puch pull switch? Please excuse the simple nature of my question, as I say, I am new to Case's. Thanks in advance.
Sam#3
06-21-2004 18:58:15
 Re: 1946 Case VAC question in reply to Mike@NY, 06-21-2004 18:05:21
The VAC uses a simple SPST ignition switch. Is the third terminal wired to anything? My first thought is someone has installed a starter solenoid.
The VAC came with a push button starter switch located in the middle of the dash.
