1976 - 885 Case by David Brown - Hydraulic Pump
Mike B.
06-23-2004 18:30:12
Where is the hydraulic pump located? Hydraulic doesn't work when it gets hot.
rhudson
06-23-2004 20:49:57
 Re: 1976 - 885 Case by David Brown - Hydraulic Pum in reply to Mike B., 06-23-2004 18:30:12
i'm no expert. but if its like my 880, it is behind the cylindrical casting at the rear of the tractor. adjacent to the pto shaft. the casting also has the drawbar brackets bolted to it on the 880. taking the cover off will give you access to the hydraulic pump as well as the high/low gearbox of the pto shaft.
