930 cltch sticking
MGM
06-25-2004 03:49:54
Only have about 15 hours on new pressure plate and clutch and when pedal is depressed sometimes you have to use your foot to pull pedal back, any ideas. Thanks in advance
Mike from S.E. MN
JW
06-25-2004 20:07:37
 Re: 930 cltch sticking in reply to MGM, 06-25-2004 03:49:54
I'll get in touch with you Monday
Bill
06-25-2004 06:46:33
Mike, Is it a 930 ck?? unhook the adjusting rod and make sure its not the pedal thats hanging up. I had a 1030 and a 730 that did that. Took the pedal off and cleaned it up real good and took care of it, If not then the fingers on your pressure plate maybe bad. Bill
