1950 SC Case Generator
Paul
06-25-2004 12:58:13
How do I get my generator to start generating again?
C. Amick
06-28-2004 09:51:00
 Re: 1950 SC Case Generator in reply to Paul, 06-25-2004 12:58:13
First make sure you are getting power from the battery to the generator. The fields must be energized for the generator to charge. One common problem is a dirty armature. Pull the dust cover off and see if there is a lot of dirt build up on the armature where the brushes run. If so, might try folding up a piece of very fine sandpaper and let the sandpaper rub the armature with the tractor idling. Do you have a voltage regulator or the original cut-out relay?
