Decrease rear tire size on 930CK DSL?
MB PC
06-28-2004 18:11:50
On our 930CK diesel (eight speed) we have 23.1 x 30 rear tires. What consequences or problems with changing these to 18.4 x 34 tires? The overall height is within 1 inch so the tractor's height would not change much and therefore the speed and RPM's should not change much either. We have found a local parts place which can get the rims and wheel hubs. What else should we consider?
Thanks for your thoughts
MB & PC
Jim P
07-06-2004 05:04:06
 Re: Decrease rear tire size on 930CK DSL? in reply to MB PC, 06-28-2004 18:11:50
If it's a six speed you will have to change the whole wheel not just the rims and I sure it's the same for the eight speed.
Jeff from WI
06-29-2004 06:25:55
Yea, you can change them. My 1030 has standard 18.4 x 34 rear tires. Why do you want to change? I'd be interested in your 23.1 x 30 tires & wheels. Let me know. Jeff.
MB PC
06-29-2004 18:33:32
 Re: Re: Decrease rear tire size on 930CK DSL? in reply to Jeff from WI, 06-29-2004 06:25:55
Hi Jeff:
We would estimate that these tires are at least 90% worn with lots of age cracks etc.
What advantage would there be for staying with the larger tire? The smaller tires a considerably less.
Thanks for your interest
MB & PC
Coloken
06-28-2004 19:18:43
When I bought my 930CK 8 speed I had the factory option of either size that you mentioned.
MB PC
06-29-2004 19:05:15
 Re: Re: Decrease rear tire size on 930CK DSL? in reply to Coloken, 06-28-2004 19:18:43
Hi:
Thanks for the info.
MB & PC
