Case Model S Identification
Corwin
07-31-1999 17:00:07
I have what I have been told is a 1944 Case S. The tag number on the instrument panel reads: 1803756S. This doesn't seem to match any of the serial number listings or formulas I have been given. I also have a line on another Case S tag number 1803941S. From the numbers this should be a newer tractor but it is mounted on converted steel wheels. Can anyone help me sort out what years these are. Another problem I am having is identifying what models/ options came out in what years, i.e. fenders, tanks, hoods, hydraulics, hitches.
Thanks for any help.
Dave
08-10-1999 17:27:47
 Re: Case Model S Identification in reply to Corwin, 07-31-1999 17:00:07
I also have a case model S tractor, as Don stated earlier, the rivet on the left side of the ser# plate also covers part of the first # which is a 4 and almost makes it look like a 1. Take a real close look it is hard to tell. My ser # on my case is 4805201S. The tractor is in use working fields in new york state. Good luck. I also contacted my local Case dealer a purchased manuals from them that might also help you. Good Luck!
Jerrie Lott
07-31-1999 20:20:35
Did you look at the rivet and make sure that it is not covering up part of the number as Don suggested you do. More than likely if the number don't match any numbers that CASE used it is marred or partially covered or for some reason being read wrong. Jerrie
