930 case differential locked up
tyler yakubchuk
06-30-2004 18:34:37
I have a 930 case with square fenders, I am not sure about the year. The differential seems to be locked up and I dont know how to help the situation. PLEASE HELP. Thank you
Jeff From WI
07-01-2004 07:57:16
 Re: 930 case differential locked up in reply to tyler yakubchuk, 06-30-2004 18:34:37
Where you from tyler? Does it move at all? I might be iterested in her if you don't? Can you send any pics? Thanks Jeff From WI.
turbo
06-30-2004 19:48:56
Our 930 years ago seized the side gears to the differential shaft.It feels like you have a locking differetial and sometimes you can use the brakes to break it loose for a short time. This is caused by the shaft gaulding to the side gears and the later 70 series used a bronze coated shaft to ease the problem. If this is the problem, you have to remove the PTO housing, the axles and bull gears, brakes and cut the side gears off and pull out the differential shaft.
