930 power steering
MGM
07-09-2004 03:11:22
The power steering was working, then intermittently, now only at full throttle does it turn just a little each way, the belts are tight for sure but I hear a little squealing, anyone got ideas, the pump or the dreaded bottom unit
Thanks in advance
Mike
GeoMo
07-12-2004 05:19:08
 Re: 930 power steering in reply to MGM, 07-09-2004 03:11:22
I had to replace the check valve in the pump on my 830
Lamont
07-09-2004 06:11:52
I'll bet the sides of your pulleys are worn out. My dad's 930 has just about worn them out. Also, check to see if the belts are riding in the bottom of the pulley. Are your belts relatively new? If not, try new belts. Be sure to check the fluid in the reservoir also. I hate to even mention something that simple, but it just recently happened to me. I checked the belts and pulleys and tightened them. Only then did I check the fluid and it wouldn't even touch the stick. It was a "DUH!" moment. Filled it with fluid and it was back to one finger steering. I'd make sure to check everything up on top before I tore into that lower unit. Those rarely give trouble.
