1949 Case SC foaming antifreeze
Rob G
07-11-2004 08:43:55
What causes the antifreeze to foam up in the radiator?
C. Amick
07-13-2004 09:27:33
 Re: 1949 Case SC foaming antifreeze in reply to Rob G, 07-11-2004 08:43:55
Could the water pump be sucking in air? Do you know if there is as thermostat installed? I think some people have had problems getting enough flow through the thermostats.
Paul f
07-11-2004 08:51:41
Hopefully just being old or contaminated but more likely is a leaky head gasket or even worse maybe a cracked sleeve. Any oily film on the coolant???
After sitting try draining a little oil from crank case...any water???
