1963 Case 611B Wide Front Utility Tractor
Oliver Auchenpa
08-02-1999 15:00:32
Have subject tractor but am having a head to block seal problem. Head has been flattened. Could the block be warped? Purchased at auction last year and ran well for several months then developed water leak problems into the oil. Removed head - evidence of blowing between all cylinders. Replaced gasket and retorqued - Filling with Antifreeze and it ran out at the head/block join.
Engine is Case 164 cu.in. Are there any around or is there a sub. Thanks for any help!
Oliver
