1955 411 case tractor
Jim Mullins
07-18-2004 08:26:52
I have a 411 case tractor for sale Serial # 8064754.The motor has been gone thru to new condition. The heads has been completely rebuilt.this tractor has a bucket on it also new paint job new tires on the front swartz wide front end hyd good new wiring if you are looking for that special tractor here it is pto works good.Does not have 3 point.This tractor will make a perfect pulling tractor.this tractor should make some of thoes green tractors place second & third in the pulling class. Jim M 269 679 4559. oldesport@netscape.net
Peter Reguin
07-21-2004 06:14:09
 Re: 1955 411 case tractor in reply to Jim Mullins, 07-18-2004 08:26:52
I have a 1958 Case 411B. What's the difference between the 411 and 411B. I have a three point hitch on mine. I am looking for transmission parts at the moment. (Reverse Geer) Do you know of any good sources for this.
JIM MULLINS
07-21-2004 19:17:29
 Re: Re: 1955 411 case tractor in reply to Peter Reguin, 07-21-2004 06:14:09
replacement parts for a 411 case tractor can be purchased through stams equiptment. phone 1 269 792 6204 good luck Jim
C. Amick
07-21-2004 14:24:53
I'll bet the gear is still available from Case/IH, if you can afford it. Post a message for John Saeli, he may know.
