Need year of Case Vac 14
Keith-OR
07-19-2004 11:10:00
Need to know what year this is,serial #6000363. Anyone have any info. Seems like I read you subtract 4 from the first two numbers, but is only good for under 60 series numbers. that would make this tractor a 1956 ??? Please confirm
Thanks..... .Keith
Russ in WI
07-20-2004 15:01:56
 Re: Need year of Case Vac 14 in reply to Keith-OR, 07-19-2004 11:10:00
I recently bought a VAC-14 and had the same problem, so I bought the buyer's guide. VAC-14s were only made in 1953-54. '53 started with #600... and '54 started with #601... So, yours is a 1953 VAC-14. There were 4,467 made that year and 1,759 made in 1954. Some of the tractors in 1954 had the hoods repainted Desert Sunset so they would sell, as the new paint scheme came out in 1955. The 14s are different from the 13s in that they have "a lower operator platform and a shortened steering column". Hope you enjoy it, I love mine -- Russ in WI
Keith-OR
07-20-2004 21:48:27
 Re: Re: Need year of Case Vac 14 in reply to Russ in WI, 07-20-2004 15:01:56
Thanks Russ. glad to finually find what the actual year of this one is. I need to replace crackshaft, because it is broken in between cyl 2 and 3. In all the years been turning a wrench never seen a crank broke like this one. Again thanks everyone....Keith
Joe (Wa)
07-19-2004 16:39:20
I don't know how actuate this link is but skip the multible letter series tractors and scroll down to mid page under VA. Joe
mj
07-19-2004 12:45:33
Ditto on the 'Seems like I read ' for over #600000. You are right on the 'subtract 4' for earlier numbers, though. I'll see if I can find the info. on 600000 plus numbers.
Thanks, mj-----------Keit
07-19-2004 16:31:42
 Re: Re: Need year of Case Vac 14 in reply to mj, 07-19-2004 12:45:33
appreciate all info..... ..Keith
