1370 clutch pedal
Joe
07-20-2004 19:30:56
the pedal will not return to the up postion without pulling it up with your foot...any reason for this??? works fine otherwise. thanks
Joe
Tremayne Hadenfelt
07-21-2004 04:02:51
 Re: 1370 clutch pedal in reply to Joe, 07-20-2004 19:30:56
Clutch linkage and/or cable seized or sticking???
Clutch pedal pivot shaft froze???
Jim Handke
07-20-2004 20:02:57
The spring to pull the pedal up is broken. It's under the dash.
Joe
07-21-2004 03:57:01
 Re: Re: 1370 clutch pedal in reply to Jim Handke, 07-20-2004 20:02:57
spring is still in place,,,could it just be weak?
Jim Handke
07-21-2004 06:05:03
 Re: Re: Re: 1370 clutch pedal in reply to Joe, 07-21-2004 03:57:01
We've never had one too weak to return the pedal. Disconnect the linkage and see if it returns on it's own.
