1949 Case SC Air cleaner/Intake cover or cap
Rob G
07-20-2004 22:32:34
Do any of you fellas know were I could find an air cleaner/intake cap or cover for a 1949 Case SC. The 145 mile trip home at 70 mph was a little to much for that part. Thanks
C. Amick
07-21-2004 09:49:03
 Re: 1949 Case SC Air cleaner/Intake cover or ca in reply to Rob G, 07-20-2004 22:32:34
The cap is welded to the intake pipe. I rebuilt mine, but it was a difficult task. If you can't find a good used one, they make replacement caps for AC tractors that look similar. If the pipe is bad, should be able to get a new one bent at your local automotive exhaust shop. Email me and I will give you some possible sources for used ones.
