SC Case
MIKE CASE
07-21-2004 17:03:04
I need to know if the 1949 case sc came with a zenith carb and if so what is the number on the carb and is there a kit available for this unit.....thanks
C. Amick
07-22-2004 11:34:28
 Re: SC Case in reply to MIKE CASE, 07-21-2004 17:03:04
I bought the deluxe kit from V A L U - B I L T Tractor Parts ($30.00). It seemed to work well. If you find the carburetor number, you can try Zenith Fuel Systems in Bristol, VA 276-669-5555.
caseman-d
07-21-2004 18:08:41
All I show in my parts book is a Zenith. Zenith should be stamped right on the body of the carb. I am showing a O5771AB, Model 161JX- outline # 0-9667. You might be able to get kit from Case yet. Set gasket C181-66 kit sevice K510. Depending on condition one may just get by with bowl gasket and needle valve. If the Case numbers are deleted then auto parts store should be able to help.
caseman-d
Les...fortunate
07-21-2004 20:06:56
 Re: Re: SC Case in reply to caseman-d, 07-21-2004 18:08:41
I got a Zenith carb kit from the dealer for my '44 SC but 90% of the contents were useless and it didn't really have in it what I needed.
caseman-d
07-21-2004 21:09:36
 Re: Re: Re: SC Case in reply to Les...fortunate, 07-21-2004 20:06:56
Thats the problem with most kits that most of it is for another carberator. We don't stock many kits but have most of the needle valve and gaskets.
caseman-d
