1935 CC Case noise
Fred Milner
07-22-2004 17:41:49
I have a noise in the area of the pinion shaft. I took the top off the trans. and pulled the bearings on the ends of the main shaft. They are good. The pinion gear has some bad pitting but don't know if that is the problem. The noise sounds like a bearing seizing but had no metal in the oil. The gear the pinion runs on looked good but has some play on the shaft. It will allow the shaft to move a little before the gear catches. This is the same shaft that the belt pully is on. The gear the pinion shaft gear runs on is about the same size as the pinion gear. The noise is not there if the clutch is disengaged. It makes the noise with the tractor in gear or out, pto in or out. I just got the tractor so I don't know how long it has been doing it. Could it be the wear on the pinion gear, the pinion shaft bearing, the clutch??? Any help would be nice. Thanks, Fred.
