1070 injectors
Bob Mo
07-23-2004 10:47:21
How do I get the injectors out? They have a notch on each side, unsure how to properly remove.Thanks Bob
Tom Handke
07-23-2004 17:58:18
 Re: 1070 injectors in reply to Bob Mo, 07-23-2004 10:47:21
When you install them, spray them with "never-seeze" so you can get them out again in the future.
Shane
07-23-2004 17:53:57
Those stupid pencil injectors are a pain in the rear! Almost impossible to get out without bending them. Tried using the Case puller but couldn't get them out so I just used a pry bar.
Jim Handke
07-23-2004 13:05:33
The notches are for a puller. My brother says that they are worthless. I use a pry bar and a pair of vise grips. We have only seen one injector that we couldn't pull out. We ended up removing the head and driving it out with a hammer and punch.
Ol Chief
07-23-2004 21:10:21
 Re: Re: 1070 injectors in reply to Jim Handke, 07-23-2004 13:05:33
Snap-On and possibly others sell a rolling head pry bar with a taper on one end and a 90 degree cam like foot on the opposite end.I have used two of these on opposite sides of the injector and succeeded on every try so far. You will probably have to use some spacers under the heel of these tools as the injector moves up. In very severe cases it may be necessary to add leverage by sliping a piece of 3/8 or 1/2 inch pipe on the tools as a cheater. Good Luck/
Bob Mo
07-24-2004 11:30:30
 Re: Re: Re: 1070 injectors in reply to Ol Chief, 07-23-2004 21:10:21
Thanks guys! I got them all out, trashed a couple but it could'nt be helped.
