Case 311-b rewiring probs.
Dave Zook
08-04-1999 18:25:35
Painted tractor, reassembled, cleaned grounding areas, ran new wiring, (1958 model) 12 volt with
positive ground, starter, lights, & etc. work ok,
but am not getting flow thru voltage regulator. can not get amp meter to show a charge or discharge. It appears that voltage regulator may be bad and the parts store shows a reg. for 311
diesel(mine is gas) is this the same reg.?? they
want $58.50 for this regulator. Is there a positive ground and a negative ground reg.?? Any info. will be greatly appreciated. Thank You in advance. Will also post on
tractor talk board. Dave Zook
Dave Zook
08-04-1999 18:45:58
 Re: case 311-b rewiring probs. in reply to Dave Zook, 08-04-1999 18:25:35
I forgot to mention that I tried to polarize the reg. but could not get a spark at generator. Dave Zook
Dave Zook
08-04-1999 18:43:50
