1370 case / fan works / ac does not.
RICH G
08-03-2004 12:56:21
I have a 1370 with cab, fan works.
a/c does not work! Where is the recharge point for this unit? I presume on the low side of the compressor but physically where is it located? I have some duracool 12 that I believe will work for this vintage of unit. Same as r12
I believe it is a older tractor because it has sight glasses on the trans. And a parking pall type of trans.
K C in Ia
08-03-2004 21:27:14
 Re: 1370 case / fan works / ac does not. in reply to RICH G, 08-03-2004 12:56:21
Schrader valves are on compressor. Also may want to locate low presssure cut-out switch and see if you have 12 volts to it when AC should be running.
Actually your 1370 is a later one if it has the Park pawl and not the cable/lever on the floor. My old 1370 and 1175 both use the over-center lever on the flor.
Rich G
08-04-2004 19:20:01
 Re: 1370 case / fan works / ac does not. in reply to K C in Ia, 08-03-2004 21:27:14
thanks for the tips guys I will give it a try on finding the valves and low pres switch. It sure runs good and has lots of power for an older tractor. But AC will help on these 85+ deg days.
Where can I get a dip stick for the trans? Dealer sold it with just a cover. Local dealer says "not avialable". From what I have heard I should not rely on the sight glasses.
Shane
08-03-2004 18:59:15
Both high (discharge) and low (suction) should be marked right on top of the compressor.
C Nesler
08-03-2004 14:27:05
My 1570 has service valves on the compressor
