Case SI
Info needed
Brian
08-07-1999 19:00:36
I recently acquired a 1943 model Case SI. I was wondering exactly what years Case produced the Model SI in. Also, how rare are these tractors? Are Case wartime tractors rarer than non-war tractors? Is a 1943 Case SI rarer than most SIs? How much is a Case SI typically worth if it's complete and restorable? Any and all info you can give me on Case SIs, I would most definitely appreciate it!
Thanks,
Brian
Craig L.
08-11-1999 22:17:41
 Re: Case SI - Info needed in reply to Brian, 08-07-1999 19:00:36
CASE SI
1942 100
1943 1010
1944 550
1945 300
1947 225
1948 450
1949 475
1951 225
1952 100
1953 125
1954 180
TOTAL SI PRODUCTION 3740
TOTAL S SERIES PRODUCTION 83,806
Hope that this bit of info will help you out
Brian
08-12-1999 10:22:38
 Re: Re: Case SI - Info needed in reply to Craig L., 08-11-1999 22:17:41
Thanks for the help! When I found this tractor, I had no clue how exactly rare it was, if it was at all. I figured that since it was a 1943 model and an industrial that it was probably fairly rare, so I picked it up. Do you have any idea how much this tractor might be worth, even though it is a little more common than I originally assumed it was? It's pretty complete, although I don't know if the engine is stuck or not. Tin is good on this one.
Thanks so much for your help.
Respectfully,
Brian
