210B PTO installation
Mike Johnston
08-12-2004 08:36:02
I bought a pto from a regular on here last summer. (You still around, Jim?) Hope to install it soon, but have a feeling there is a sleeve or something else that I'll need.
Its going into a 210B with a 4 speed and shuttle reverse if that means anything.
Will the tractor need to be split to install the pto? Sure looks like it would just go in the back end.
Thanks,
Mike
Jim M
08-14-2004 18:55:23
 Re: 210B PTO installation in reply to Mike Johnston, 08-12-2004 08:36:02
The front spine of the pto should slide into a spline in a coupler or in the hand clutch assy. They would be at the front of the transmission bolt to the front of the 4 speed. You may have to spilt it to get it right. I'll try and look at my book. Jim
C. Amick
08-12-2004 13:43:34
I changed the one in my 311. The whole thing just slid right out the rear.
Mike Johnston
08-12-2004 15:28:37
 Re: 210B PTO installation in reply to C. Amick, 08-12-2004 13:43:34
Thanks, C.
This tractor has never had one installed, that's why I'm thinking there may be a union or sleeve missing. I had the shifter top off the torque tube a year or so back, and seems like I remember seeing a plug over the hole where the pto shaft would go through.
Glad to know it can be done without splitting..... ..
Dr Cy Kosis
08-12-2004 20:02:20
 Re: 210B PTO installation in reply to Mike Johnston, 08-12-2004 15:28:37
Mike we going to see you at Temple this year?
You'll have to check out "PROJECT: Rust Runner" if you make it. It ought to give the old Thunder Chicken some competition.
Mike Johnston
08-12-2004 20:49:02
 Re: 210B PTO installation in reply to Dr Cy Kosis, 08-12-2004 20:02:20
Yep,
Might take you up on that offer from last year to tool around the grounds on the ol' L, if it still stands.
Mike
Dr Cy Kosis
08-13-2004 07:20:28
 Re: 210B PTO installation in reply to Mike Johnston, 08-12-2004 20:49:02
Good deal! I'll go you one better....Take 'em both for a spin. I should have the L and the C both in attendance. I've never been able to get more than one at a time to any of the shows before, other than the local ones.
