Case DI
MIKE SHELDON
09-05-2004 07:03:29
Well that Case CD turned out to be a DI, looks like it could have been an aircraft tug. My question is:1 is the engine serial # the same as the tractor #. 2 can i get a new serial # plate. 3 does anyone have the lower section of the air cleaner for sale. and last does anyone have radiator parts for this tractor. thank you for any information.
caseman-d
09-05-2004 07:10:52
 Re: Case DI in reply to MIKE SHELDON, 09-05-2004 07:03:29
Unless the engine has been changed the serial number should be the same. Might check the archieves as I thing someone posted earlier about getting new serial # tag. May have the parts your looking for but where exactly are you located and what are you loocing for on the radiator???
caseman-d
MIKE SHELDON
09-05-2004 07:37:22
 Re: Case DI in reply to caseman-d, 09-05-2004 07:10:52
I'm in massachusetts, and i'm looking for the cast iron side plate on the left side, and maybe the core. Also do you know where i can get a shifter boot, and a 6 spoke steering wheel for the same. thank you again.
caseman-d
09-06-2004 19:52:56
 Re: Case DI in reply to MIKE SHELDON, 09-05-2004 07:37:22
The boot is still available from your Case dealer. The steering wheel you will probably have to find from a salvage yard. I live in SD so shipping may get expensive.
caseman-d
