400 diesel repair
jon
08-13-1999 12:11:18
I just purchased my first tractor a case model 401.It ran good ,but needed pto clutch plates.I replaced the plates and started changing all the filters and oils.It was running good,but a couple weeks later I started it and it sound like it was missing and die.Now when I try to start it anti-frezze comes out the exhaust.Someone had JB welded a nipple with a screw cap on the radiator.
I wondered if this might of cause my problem and cracked the block or head.Thanks for any info Jon!
Patrick Tercho
08-14-1999 12:58:46
 Re: 400 diesel repair in reply to jon, 08-13-1999 12:11:18
Jon-
Sounds like the heads are going to have to come off and see what's going on in there. Got a feeling the first gentleman is right that wrote to you, a crack in one of the heads. It doesn't sound like a cracked block or sleeve, because then you should be getting water in the oil pan or blowing water out of the radiator from the engine compression. We had a hard time getting ours to seal the gaskets, but the heads were good. When you go to put the heads back on, use some Permatex Seal-a-Gasket spray on the head gaskets and then torque the puppies. Run the engine about 30-45 minutes and then shut her off and retorque the heads. Yeah, I know you have to take the vale rockers off again, but it's worth it cause you'll get another 1/8 to 1/4 turn out the head stud nuts. Then reset the valve lash when the engine is cold. Hope this helps a little.
Pat
jon
08-14-1999 14:37:25
 Re: Re: 400 diesel repair in reply to Patrick Tercho, 08-14-1999 12:58:46
Thanks for the info.Do these tractors have a pressurised type radiator system? Is it better to have my radiator rebuilt or can you buy new ones.
Patrick Tercho
08-15-1999 11:39:53
 Re: Re: Re: 400 diesel repair in reply to jon, 08-14-1999 14:37:25
Jon-
Yeah, they use a 4 lb. pressure cap on the radiators. At full load the engine temp runs at 195 degrees/180 degrees just puttering around.
I know I've seen reworked radiators for sale in Surplus Tractor Parts catalog, don't know how much they'd want for it. Probably pretty steep, that's a big radiator. If you've got a good shop around your place, you might try them to see if they can rebuild it. Let me know how you make out.
Pat
jon
08-17-1999 18:52:04
 Re: Re: Re: Re: 400 diesel repair in reply to Patrick Tercho, 08-15-1999 11:39:53
Looks like I have a cracked head.It appears to have been cracked for some time.May have bar leak in it.Is tractor salvage yards the best place to start looking? Thanks jon!!
Patrick Tercho
08-18-1999 04:41:51
 Re: Re: Re: Re: Re: 400 diesel repair in reply to jon, 08-17-1999 18:52:04
Jon-
If you have some good salvage yards close by, they would be a real good place to try first. I know Central Tractor and Surplus Tractor Parts both list rebuilt heads for the 400, but the price is $400-$500. If you get a used head, it would be worth the money to have a valve job done on it, and while you have the heads off, put new freeze plugs in them. I did a valve job on mine a couple years ago, and then got a anti-freeze leak from the old freeze plug. Not happy.
Pat
She don't sound good
08-13-1999 23:02:10
Yes these engines have a poor track record when it comes to (HEAD) Pun intended!
Good Luck.
