1070 not going into gear easy
Can't even use
09-09-2004 18:28:21
Just recently one of our 1070's has decided it be time to join the others in having tranny problems. First one had the Belleville Ring on the flywheel get weak and eat the torque limiter plate up (just fixed that), second one has evidently sheared off the bolts holding C2 and C3 together or the seals there are shot (waiting for time to split this one) and now this one grinds the gears when you step on the "clutch" pedal. Doesn't matter how long you hold it nor what gear. Thinkin maybe the three double springs that push the reaction plates apart on C1. Anyone have any other possible ideas, don't have time now to split this one but it is next and looks like maybe in about a week and a half. Just curious as to what to really check for. Thanks, Shane
Leland
09-11-2004 20:04:35
 Re: 1070 not going into gear easy in reply to Can't even use MY name, 09-09-2004 18:28:21
How are you changing hyd filters this seems to be the trick for keeping those stubborn tractors going . dealer said run them no more than 200hrs
nna
09-09-2004 21:19:20
Make sure the clutch linkage is right. You might have to adjust the stop bolt so the pedal goes down far enough to move the inching spool to the end of its travel.
jim1950
09-09-2004 19:31:17
C-4 stops the tranny to let you shift. The clutch plate may be shot, or the o-rings on the piston.
Can't even use my name
09-10-2004 06:03:34
 Re: 1070 not going into gear easy in reply to jim1950, 09-09-2004 19:31:17
Yep you are right! Still looks to be a realtively easy fix, ha ha! Hopefully the parts tractor has good parts if I need them. Thanks
