1976 DB 885 help
Rickb
09-11-2004 12:22:54
I have a chance to buy an 885 for cheap. It has a couple of problems I need to know more about before I jump in. It needs a water pump, starter work, shaft seal on the power steering pump and the engine has massive blowby; one cylinder (at least) is passing compression into the crankcase. Is this 3 cylinder diesel wet sleeved, dry sleeved, or parent bore? Are engine parts available in the aftermarket, or is mother Case my only option? Otherwise, this tractor looks OK and the clutch, tranny, PTO, and hydraulics are very good. All input apreciated. RickB
Elmer
09-12-2004 05:40:37
 Re: 1976 DB 885 help in reply to Rickb, 09-11-2004 12:22:54
That engine is parent bore. Aftermarket parts are not a problem. I have quite a bit of inventory here myself. Can supply you with the proper manuals and parts too. They are a great little tractor. Most fuel efficient you will ever come across. Left my email open if you want more answers.
Glenn FitzGerald
09-11-2004 20:49:00
I know nothing about that particular tractor but basket cases like that can get VERY expensive by the time you get them up to your standards. It better be VERY cheap, in my opinion. Glenn F.
RickB
09-12-2004 06:22:11
 Re: 1976 DB 885 help in reply to Glenn FitzGerald, 09-11-2004 20:49:00
It is. Thanks for the thoughts. You are correct, and that is why I came here to get more info from guys like Elmer to inprove my odds. Not my first rodeo.
