1/2 DC
Bill N
09-16-2004 19:13:39
Hello Guys, Need a bit more help on changing my starter ring gear on the fly wheel. I have the DC split in half and now want to know if I have to take the 6 or so clutch plate bolts off and then remove the clutch and then the flywheel to remove the ring gear. Or am I missing something? Thanks Bill
Glenn F.
09-16-2004 19:17:41
 Re: 1/2 DC in reply to Bill N, 09-16-2004 19:13:39
Yes, remove the 6 or so clutch bolts. This will expose the 6 or so flywheel bolts. Remove these.
Bill N
09-16-2004 20:08:35
 Re: 1/2 DC in reply to Glenn F., 09-16-2004 19:17:41
Is the clutch pressure loaded and will fly apart once I remove those bolts?
Glenn F.
09-16-2004 21:22:51
 Re: 1/2 DC in reply to Bill N, 09-16-2004 20:08:35
It's been a little while since I took a DC clutch apart but nothing much is gonna happen as you loosten the bolts. Certainly no dangerous or 'jack-in-the-box' type experience. Glenn F.
L.Lamp
09-17-2004 19:40:52
 Re: 1/2 DC in reply to Glenn F., 09-16-2004 21:22:51
If the clutch was disengaged before you split the tractor there will be no pressure on the disk. If it wasn't, put a recking bar against one of the two engagement pins and pry it out, back toward the transmission or just loosen the clutch plate bolts and pry it back with a screw driver if it won't move by hand.
