580C OIL LEVEL GOING UP
ROB
08-14-1999 18:15:58
The engine oil level in my 580ck is on the rise and I have no idea where it's coming from. The power shuttle fluid level does not change.I believe the hydraulics are seperate...correct me if I am wrong.Anybody have any suggestions?
Jerrie Lott
08-14-1999 19:50:43
 Re: 580C OIL LEVEL GOING UP in reply to ROB, 08-14-1999 18:15:58
Its a diesel right. You probably have a seal leaking in the injector pump and you are getting diesel fuel in the crankcase
Bob
08-16-1999 20:28:28
 Re: Re: 580C OIL LEVEL GOING UP in reply to Jerrie Lott, 08-14-1999 19:50:43
I agree with the other follow up. It is a diesel and the umbrella seal on the fuel pump is allowing fuel into the crankcase. The bigger question is, how long have you had this problem? If it has been long you may need to check your bearings - fuel in the oil can cause bearing failure. I would suggest that you have someone that knows how to replace the umbrella seal do it for you - it can be a hassle.
rob
08-21-1999 10:25:55
 Re: Re: Re: 580C OIL LEVEL GOING UP in reply to Bob, 08-16-1999 20:28:28
Thank you Jerrie and Bob.Yep its diesel fuel.Cleanest motor in town.I didn't hear any unusual knocking so I think I caught it in time.Again, thanks for your help!
