1950 Factory LA Propane
Engineer20
09-20-2004 09:39:52
Hello,
I have corresponded with Mr. Rich Tworek of the Case Corp. about a build card for my 1950 LA. It was built for use with the propane fuel. There seems to be some confusion with when you could get propane from the factory. The book I have says 1952 but this could not be correct as my tractor was built 2 years before.
Any one have any other info. to add?
Thanks!,
Mike
mike's600
09-20-2004 18:02:01
 Re: 1950 Factory LA Propane in reply to Engineer20, 09-20-2004 09:39:52
I just got my 52 LP in the shop. M&W overbore kit, and the head checked out perfect. I painted the transmission and engine Sat. I will have the sheet metal done shortly. The LP version is a great looking tractor.
Engineer20
09-20-2004 18:39:36
 Re: 1950 Factory LA Propane in reply to mike's600, 09-20-2004 18:02:01
Hi mike's600,
Sounds like you are where I hope to be next summer with my tractor. I'm changing all fluids and filters, sparks plugs, new front tires and going to put it away for winter and then start on it next spring. The motor and rear end have already been gone through. would like to see a pic sometime.
Mike
DCTOM
09-20-2004 10:13:20
post serial number maybe i can look up card and shed some lite on it dctom
Engineer20
09-20-2004 13:18:00
 Re: 1950 Factory LA Propane in reply to DCTOM, 09-20-2004 10:13:20
Hi DCTOM,
Here is the number- 5418740LA
Thanks,
Mike
DCTOM
09-20-2004 17:39:32
 Re: 1950 Factory LA Propane in reply to Engineer20, 09-20-2004 13:18:00
engineer, you LA is deffenatly a factory stock LP gas unit, dont know what book you are useing but case started building LP tractors in 1950, i had a DC LP and it was a 1950 5418740 LA was built jun 14 1950 and shipped to swinton implement co, hunter texas dec 4 1950 the LP unit is #4010AA lpgas dctom
Engineer20
09-20-2004 19:08:41
 Re: 1950 Factory LA Propane in reply to DCTOM, 09-20-2004 17:39:32
Hi DCTOM,
My book is "CASE Tractors" Illustrated Buyers Guide, second edition.
On page 119, second paragraph, first sentence it says: "In 1952, the company introduced LP-Gas equipment for the LA."
On page 122 under the picture it says:
"In 1952, Case offered LP-gas equipment for the Model LA. Performance matched that of the gasoline-fueled engine, but generally ran at a lower fuel cost."
Mike
DCTOM
09-21-2004 08:32:59
 Re: 1950 Factory LA Propane in reply to Engineer20, 09-20-2004 19:08:41
YAH I KNOW THAT BOOK, CASE INTRODUCED LIVE HYD AND PTO IN 52 ALSO AND NO ONE SEEMS TO REMEMBER THAT, BUT LP WAS INTROCDUCED IN 1950 TOM
