DC brake seals
Larry O.
09-21-2004 17:41:16
Is there 1 or 2 oil seals on each brake. Can you get the seals at Napa as i am 60 mi from a cih dealer. Thanks
mikefromiowa
09-22-2004 05:40:10
 Re: DC brake seals in reply to Larry O., 09-21-2004 17:41:16
take the seal to napa also. I've done that with about all the brake, pto, axle, belt pulley seals on my VAC. I used 2 on the PTO, axle, and belt pulley due to slight wear on the shafts. turn inner seal in and outer seal out.
L.Lamp
09-21-2004 19:45:37
Be very careful to put some thin shim stock or aluminum foil around the brake disk splines or you will cut your new seals when you slide them back in place and the seals will still leak!!
DCTOM
09-21-2004 17:44:35
take case numbers to your nearest mill supply and they can cross them and get seals, if the new ones are the real thin ones can put two on each side tom
