1959 Case 310B Low Oil Pressure
Buddy
09-28-2004 04:36:57
Gas 148 Engine: Oil pressure reads 20 lbs when tractor is first started. When tractor warms up (180 F) oil pressure drops to 5 to 10 lbs. Useing 30 wieght non detergent oil. What causes oil pressure to drop?
Dennis/Ohio
10-02-2004 03:29:36
 Re: 1959 Case 310B Low Oil Pressure in reply to Buddy, 09-28-2004 04:36:57
If I recall correctly, check oil pressure hot but at full engine speed. 14-20 psi.
C. Amick
10-01-2004 12:45:05
My guess is worn engine bearings. I would put a can of oil treatment (STP or equal)in it each time I changed the oil. Make sure you add it with the tractor running after you have put some new oil in it. Make sure you haven't lost the metal filter housing stem that goes up into the oil filter.
Buddy
10-03-2004 16:52:58
 Re: 1959 Case 310B Low Oil Pressure in reply to C. Amick, 10-01-2004 12:45:05
Great Improvement! Metal filter housing stem in place. Changed filter and oil. Added STP Oil Treatment (15 fl. oz.) while the engine was running. Oil pressure now at 15 lbs when engine temperature is 180F.
Thanks for your help.
