1175 Diff. Lock Locked up
Jerryh
09-28-2004 21:00:01
I am having problems with an 1175. The rear wheels are locked together and I can't turn,it wants to go straight. I have looked for a differential lock lever or pedal and can't find one. I don't see anything on the rearend that would resemble a diff. lock. Can anyone help me find out what locks the rear wheels together?
jerryh
09-30-2004 06:34:19
 Re: 1175 Diff. Lock Locked up in reply to Jerryh, 09-28-2004 21:00:01
Thanks, I am going to take the top off and see what happened I will let you all know. I appreciate your info. Thanks Jerry
turbo
09-29-2004 11:13:39
The differential cross shaft has seized to one or both of your side gears shafts. The brakes are mounted onto the side gears shafts and drive the bull gears.The crosshaft supports both side gears, thus it is like locking your differential.
hoop
09-28-2004 23:48:54
you may have a bad spider gear or worn pin on the center section that carries the ring gear
John Saeli
09-29-2004 05:14:26
 Re: 1175 Diff. Lock Locked up in reply to hoop, 09-28-2004 23:48:54
It sure does sound like a differental problem, but check to see that the brakes aren't locked on. Sometimes the auto-adjusters get too agressive.
darBy
09-28-2004 21:15:44
1175s did not have a diff lock.
