About my 430 case
TONY
08-16-1999 10:44:20
I recently purchased a 430 case. The only info. the seller gave me was tht it was made between 60-69, and it was about 45hp..Is this accurate? Also the only serial no. Ican seem to locate is 261T05348, and it is located on the side of the engine block. I would like to know if this is the actual serial no.and if not how do I find it .
Also any other info at all about this tractor would be appreciated. Thanks TONY..... ..
Pat
08-21-1999 14:01:12
 Re: about my 430 case in reply to TONY, 08-16-1999 10:44:20
Case told me my 530 eng. ser. no. of 289T02319 indicates a 1965 model. I have no tractor nos. anywhere.
Tractor ser. nos. for 530,.... and some others??
Year Starts at;
1960 8160001
1961 8168801
1962 8190001
1963 8208001
1964 8229001
1965 8253501
1966 8279001
1967 8306001
1968 8332001
1969 8356251
Shaun In Wisconsin
08-16-1999 20:10:05
The serial NO# tag on the 430 were set buy the dash cluster If it's a gas tractor it should say somthing like 441, then the serial No# under that.
if it says 431, this would make it a diesel G- 33 HP
D- 34 HP
There are certain improvments that CASE had made over the 9 year period that will give tell tale bits of information, letting one Know approx. what year machine that you have. Well see if you can find the tag then get back to us.
