1030 hydraulics
pete(tx)
10-02-2004 14:48:38
3 point won't operate I have rebuiit the pump freed up the pistons on the control valve still won't work any help or suggestions as to where to look next will be appreciated
John Saeli
10-02-2004 18:31:31
 Re: 1030 hydraulics in reply to pete(tx), 10-02-2004 14:48:38
Hey Pete: I assume the remotes work OK? If the sensing arm underneath that runs vertical up through the rear end housing gets out of time, it screws things up.
pete(tx)
10-03-2004 11:31:28
 Re: 1030 hydraulics in reply to John Saeli, 10-02-2004 18:31:31
thanks John i will check this and reset according to manual this whole sensing system is messed up part of it is missing would there be a way to remove it all this tractor will be used for is hay work moving round bales and running the baler and probably the batwing mower
