2290 case powershift trouble
May'sLick
10-14-2004 19:44:49
my 2290 powershift only works in the 1st gear of each range. when i shift into 2nd or 3rd it will stop pulling. it does not stop abruptly however. i have cleaned the powershift control and replaced the springs in the valves as well as replaced the powershift spool itself. the service manual does not describe this problem. can anybody help? thanks
Can't even use my name
10-15-2004 05:56:42
 Re: 2290 case powershift trouble in reply to May'sLick, 10-14-2004 19:44:49
Sounds like the clutch pack sheared off the bolts that hold it together. Possible the clutches are ate up too. Gonna cost around $3000 min if you take it in or more. Do it yourself and it will cost half that. Just split a 1070 that had the same problem, not too bad. You don't have to take the cab off to split.
Leland
10-15-2004 01:44:18
Get out the check book, farm I worked on had a 2590 do the same pull off cab split and replace a bunch of pricey parts.
c hess
10-15-2004 08:21:30
 Re: 2290 case powershift trouble in reply to Leland, 10-15-2004 01:44:18
not nessary to removecab. 2 of us split 1070 in about 2 hrs. need stand to hold engine an front--- floor jack for rear--- no special tools
Leland
10-15-2004 20:53:30
 Re: 2290 case powershift trouble in reply to c hess, 10-15-2004 08:21:30
On this 2590 they took of cab split and took off both rear axles to get at trans to fix.
Leland
10-15-2004 20:53:35
