1070 case hydraulics
leon gillespie
10-21-2004 02:05:48
can anyone help me with a diagram of 1070 case hydraulic system . I want to put on an auxillary remote coupling and need to know where to plumb it in
thanks
leon
KYCASE
10-22-2004 20:08:48
 Re: 1070 case hydraulics in reply to leon gillespie, 10-21-2004 02:05:48
The 1070 should have ractory-installed remotes (2 sets). The hydraulic oil leaves the pump (mounted on the back of the tractor on the upper part of the P.T.O. housing) and travels along the right side of the tractor to the diverter valve (diverts flow to the P.T.O. clutches). Then leaves the diverter valve and travels back down the right side of the tractor to the remote valve (mounted on the back of the tractor just above the P.T.O. housing). Then travels to the 3pt valve mounted under the floor. The system pressure relief valve is located in the remote valve. Hope this helps.
