Case 611B
Butch
08-19-1999 18:55:19
Just bought a 611b with case o matic. Have no experience with this. Serial # 6096317, is this a 58 model???? what hp????It seems to run ok.Also what is the difference between GO90 and 90 mineral oil??
Oliver
08-22-1999 11:07:28
 Re: Case 611B in reply to Butch, 08-19-1999 18:55:19
Hi Butch - posted a reply on Friday but it never appeared - I have a 611B as well. I also have the workshop manual and the operator manual. Neither of the publications states the horsepower - all kinds of other specs but no h/p. Mine was running for a while last year after I bought it at auction but has a "water in the oil" problem that I am trying to track down.
I live in Thief River Falls, MN - you anywhere close?
Cheers
Oliver
Butch
08-22-1999 15:28:05
 Re: Re: Case 611B in reply to Oliver, 08-22-1999 11:07:28
Oliver: Just found this info. don't know if accurate
611b PTO 44hp 56 eng. 37 dbar
Jerrie Lott
08-22-1999 20:23:50
 Re: Re: Re: Case 611B in reply to Butch, 08-22-1999 15:28:05
That can't be right, it has a 377 cu in diesel engine right. That is the same engine that was in a 900 which was over 70 hp. I would think somewhere between 60 and 65 hp would be closer.
BLR
08-26-1999 12:18:48
 Re: Re: Re: Re: Case 611B in reply to Jerrie Lott, 08-22-1999 20:23:50
The 611B is a smaller tractor of completely different design than 600 diesel you refer to. The 611B is at the top of the small tractor line in the 200, 300, 400, 500, 600 series. The large tracotr line of that vintage would be the 700, 800, and 900 series.
Butch
08-23-1999 17:16:46
Sorry Jerrie this is a gas engine.
Lorne
10-01-1999 22:52:40
 Re: Re: Re: Re: Re: Case 611B in reply to Butch, 08-23-1999 17:16:46
sorry to bust in guys, but I have a 610B, serial #6120114, reputed to be 46 hp., 4 cyl. gas. It has a broken crankshaft and I am looking for a replacement. Can anyone help? No. on crank is G11709.
Lorne
10-01-1999 22:10:56
Butch
08-22-1999 14:55:23
Oliver: hope the water problem is'nt a cracked head or block. Don't know if they have wet or dry sleeves.
BLR
08-26-1999 12:20:40
 Re: Re: Re: Case 611B in reply to Butch, 08-22-1999 14:55:23
The 611 has a dry sleeve engine
jubba@digital passage.com
03-04-2000 22:08:40
 Re: Re: Re: Re: Case 611B in reply to BLR, 08-26-1999 12:20:40
price range of 611b Case tractor
ju
