POWER SHUTTLE TRANSMISSION
MIKE R
10-23-2004 08:47:30
1984 580C BACKHOE TRANS SLIPS IN ALL GEARS, PULLED TRANS TO INSPEC. AND REBUILD, FOUND ALL NEW CLUTCHES AND FRONT PUMP INSTALLED,I ONLY FOUND THE FORWARD CLUTCH HUB HAD NOT BEEN HONED, STILL HAD DEEP GROOVES IN IT, ALSO THE MAIN SHAFT DRIVE GEAR END HAD A BROKEN SEAL, WOULD THIS BE ENOUGH TO MAKE TRANS SLIP, ALSO THE SELONOID IS DISCONNECTED NO WIRES ATTACHED!
