1950-51case vac
jerry cottom
11-03-2004 02:46:33
when i got it, it smoked,had oil in rad.but no water in oil,but run for an about 10mins. it blowed water/oil out of rar. overflow. my boys took it out and used it hard put in the barn cleaned out rad.now i got a little oil leak out side behind carb.still smokes little, oil perssure still 70-90. told bad head gasket? but now I was mowing with it and the clutch went down and stayed ,i think i popped the perssure plate or some thing,can start in gear, need info. on parts. brakes went but last yr. took to have relined 300$ so did my self works great(jerry )
GeoMo
11-03-2004 05:39:48
 Re: 1950-51case vac in reply to jerry cottom, 11-03-2004 02:46:33
I broke the end of the linkage rod on my VAC. I welded end but had to break tractor to replace.
