2094 2096 4690 PTO Problems
John Saeli
11-13-2004 17:23:41
Can anybody tell me why the PTO Levers on the above tractors will not stay engaged & how to fix the problem.
Elmer
11-14-2004 07:04:17
 Re: 2094 2096 4690 PTO Problems in reply to John Saeli, 11-13-2004 17:23:41
John i remember something about adjusting a detent spring. I'll get out my shop manual and see if i can find out more and get back to you.
Elmer
11-14-2004 15:43:30
 Re: 2094 2096 4690 PTO Problems in reply to Elmer, 11-14-2004 07:04:17
Looked in the parts book and i think if you remove the pressure line to the pto from the flow divider valve, there is an allen screw in there. Turn it in one turn. I did this about 5 years ago on a 2290. I'll make a phone call to a guy i used to work with at the Case dealer and verify this.
John Saeli
11-14-2004 18:37:10
 Re: 2094 2096 4690 PTO Problems in reply to Elmer, 11-14-2004 15:43:30
Hey Elmer: Appreciate that. Keep me posted. Thanks
Elmer
11-15-2004 15:44:27
 Re: 2094 2096 4690 PTO Problems in reply to John Saeli, 11-14-2004 18:37:10
Hey John give me a call 519 363 2663.
case trader
11-13-2004 19:00:48
my experience has always been clutch plate problems letting the piston travel to far then loosing preasure then letting the lever kick back out preasure holds it in saometimes it will kick out imediatily sometimes when the oil gets warm hope this helps, now tell me why my 2096 is so hard to start after setting overnite.
John Saeli
11-14-2004 05:56:24
 Re: 2094 2096 4690 PTO Problems in reply to case trader, 11-13-2004 19:00:48
Hey Trader: These PTO's have little wear. funny thing is, that my 870 with many PTO hours stays engaged. My 2096 starts the same as yours when the Temp is 30F & below. It won't stall as much if I open the throttle wide open, not letting it rev up, of course.
case trader
11-14-2004 10:02:03
 Re: 2094 2096 4690 PTO Problems in reply to John Saeli, 11-14-2004 05:56:24
hey john i had a 90 series that wouldn't stay in so i backed another tractor up to it hooked a line from good tractor pto to problem tractor kicked on still wouldn;t stay on so at least i knew it was in the pack not valve i like chalenges.this 96 seems a lot harder to start than my others just seems to be loosing prime why doesn't it start like my 200,000 mile dodge.
