2096 starts like hired help
case trader
11-13-2004 19:07:02
my 2096 with the cummins after setting overnite is very hard to get going again cranks good and finally hits usualy starts an dies at least 3 times then when it sarts takes 15 seconds to rev up ,no misses runs on all 6
big orange
11-14-2004 16:48:53
 Re: 2096 starts like hired help in reply to case trader, 11-13-2004 19:07:02
How many hours does the tractor have?Could be low compression.
jim handke
11-14-2004 08:32:38
I"ve never been around a 2096, so I don"t know if you have a mechanical primer on the pump. I have a 2470 that"s almost that way. I have to pump the primer until I feel resistance, then it will start like it should. Maybe fuel is leaking back into the fuel tank on your tractor, like mine is doing. It"s worth a try.
case trader
11-14-2004 09:52:53
 Re: 2096 starts like hired help in reply to jim handke, 11-14-2004 08:32:38
temp. doesn't seem to matter 50-60.i replaced the lift pump no difference hooked a tank directly to top of inj. pump still no difference seems to be loosing prime no fuel in oil could a injector be at fault?
Doc Larry
11-14-2004 03:38:56
Trader,
Don"t know where you are. What sort of overnight temperatures do you have this time of year?
Larry
