1958 CASE 530 TORQUE CONVERTER
BILL BRYANT
11-27-2004 11:41:17
NEED INFO ON TORQUE CONVERTER FOR 1958 CASE 530. NEED REPAIR INFO.
Brent Behner
11-28-2004 15:07:19
 Re: 1958 CASE 530 TORQUE CONVERTER in reply to BILL BRYANT, 11-27-2004 11:41:17
Bill, Case 530 Were Made In 1960-1969. Is Yours Eagle Hitch Or Draft-O-Matic? 1st. Get A Service Manual. 2nd Get A Good Hyd. Pressure Gauge. Check Clutch Pressure At Spool Valve At 1500 R.P.M. 105-120 P.S.I. Check Convertor Pressure, Valve Beside Spool Valve,30-40 P.S.I. Oil Pump Pressure At Top Fitting Of Filter,In Front Casting Remove Top Line & Install Gauge 160-235 P.S.I. @1500 R.P.M. Hope This Helps BRENT
